Rotate view question
danny_carballodanny_carballo Member Posts: 6 ✭✭
I've been using Onshape for quite some time where the default behavior has been to rotate about the mouse point when I right-click to rotate. As of today, I'm noticing that no matter what, my right-clicks are rotating about the origin or some other point in space not on the model. How can I revert this behavior? Any help would be great!
  • KrzKrz Member, Developers Posts: 68 ✭✭✭
    Right-mouse click over any point of geometry (end of line, moddle of line...) then rotate
  • danny_carballodanny_carballo Member Posts: 6 ✭✭
    @Krz
    It occurs intermittently whether or not I am on hovering or geometry or not. For example, if I right-click over a part face it will not rotate about that part face.
    It rotates only around points.
    Is this a recent change? This only started occurring for me starting today.
  • EvanReeseEvanReese Member, Mentor Posts: 2,340 ✭✭✭✭✭
    @danny_carballo
    could be a bug. I'd submit a support ticket here:
    Independent Onshape Consultant | Industrial Designer
    Thanks, already did.
    Update for anyone else experiencing this issue - it appears to be browser related. I am using Brave which has the problem but Chrome does not appear to have the issue.
