Force decimals in drawing dimensions to show which tolerance it has?
paul_ragot
Member Posts: 18 ✭✭✭
Hello,
Is there a way to force the display of decimals in a dimension in a drawing:
ex: value is 30mm. with +/- 0.005
Default tolerance for dimensions with 3 decimals is set to +/- 0.005mm
How can I display 30.000 without having to force the value to 30.000- then it is underlined (overidden value)
Displaying 30.000 means it is +/- 0.005
Thanks.
Paul
Thanks.
Paul
Once you have adjusted this, you can right-click the tab, export as DWT, and import it into a new document to use as a template (you can add more DWT files to that document to add more templates). Be sure to make a version in that document to reference them.
However, the default templates have a precision of 0.123 for the ANSI Inch templates and 0.12 for ANSI metric & ISO templates, which I think is pretty reasonable. To navigate to the default onshape templates, select the onshape tab in the top left when making a drawing.
Hope this helps!
Thank you for your answer. The drawing properties page allows to force leading and trailing zeroes, but this applies to *all* dimensions in the drawing.
However, I did find the answer to my question in that page:
set the "length trailing zeroes" - so that all dimensions have 3 trailing zeroes (using a precision of 0.123)
Then I can edit individual dimensions and set the precision to 1 or 2 decimals- and it works fine (see the dimensions with 1 and 2 decimals):
So all is good.
Thanks.
Paul.
