Right-Drag Center of Rotation Suddenly Changed
I exited OnShape and when I returned the center of rotation on right-drag is far from the origin.  It causes the model to swing in a big circle and go out of view when rotated - very inconvenient.  I tried exiting and returning again but the problem remains.  I've never seen this happen before.   What could be the problem?
  • alnisalnis Member, Developers Posts: 452 EDU
    Does it also rotate weirdly when starting the right-drag on the model? Is the part/assembly particularly large/long in any way?
  • christopher_graham586christopher_graham586 Member Posts: 47 ✭✭
    Thanks for the suggestions, but no it's the same model that rotated normally before this started.  However I just noticed another posting about a new bug with mouse rotation when using the Brave browser (which I use) so probably that's the problem
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,886
    Supported browsers: Chrome, Firefox, Safari, Opera, Edge (Chromium).
