Can you create a cut feature in an assembly?
It is quite common to create a welded assembly and then machine after welding. A separate part or assembly is created for machining. Is there a way to do this in OnShape?
1
- Part studios define the geometry
- Assemblies define the motion
There are approaches that I can think of. For both, you'll want to first model the whole welded assembly within a single part studio with the Beams custom feature.- Create a configuration checkbox (or table if you want) to configure the suppression of all of the post-welding operations. This is simpler and keeps everything very neat, but if you have many post-welding operations, the configuration table/checkbox might get unwieldy and you do need to configure suppression for each feature separately. An advantage of this is that you have a single model/source of data to include in assemblies (e.g. with fasteners), so you can freely toggle the manufacturing operations with less concern about mates breaking, and exploded views will automatically "just work" between both configurations.
- Derive all of the parts into a second part studio and do any edits there. When making the drawing, you can insert either/both part studios to show how everything goes together. With this method, you don't need to individually suppress any features, and you don't have to manually update a configuration table. However, it becomes a bit hairy when you start to add the parts to assemblies because there isn't any clean way to switch back and forth between pre/post-machining after welding.
Hope this helps! Let me know if you'd like me to put together an example.@alnis is my personal account. @alnis_ptc is my official PTC account.
Please try In-context modeling https://cad.onshape.com/help/Content/in-context.htm
You can create a new part studio in context of the assembly, in part studio, make copies of welded parts, combine them in a composite part and make what-ever modeling changes are needed. Hope this works for you.
Something like a welded table would be a lot of work. Better if we have a way to treat and assy as a weldment.
https://cad.onshape.com/documents/81cf8d5fab2f5bf37fdf9aa9/w/0c43eaa1e7778f35c1e38edb/e/d0d465135711076ba3aa5aad
Another option that's in between configurations and derived parts is making a copy of the part within the same part studio and applying your post weld features to the copy. Like a derived part, it's treated as a separate part. Like configurations, it's all in one part studio, but without haven't to remember which features to suppress. But you do have to be careful with your context (i.e. which body your features are applied to).
Please cast your vote on this IR.
https://forum.onshape.com/discussion/6058/weldments-and-associated-tools
