Where can I access the parts being used in the Onshape Assemblies tutorials to practice myself?
irene_hillirene_hill Member Posts: 2 EDU
I previous post mentioned they were found in Step 1. However, that is not the case now. I tried searching the public files but many are view only. Please advise.
https://learn.onshape.com/learn/course/fundamentals-onshape-assemblies/creating-an-assembly/starting-an-assembly
  • KatieHuffmanKatieHuffman Member, Onshape Employees, Developers Posts: 194 image
    @irene_hill the exercise documents can be found in Step 1 of an Exercise- labeled Exercise: XXX. Each exercise has an intro page and then the Steps begin. You must copy the document to begin the exercise, as indicated in Step 1. The link you sent is a video- the documents used in the videos are not provided.
