Boolean
VM
Member Posts: 12 PRO
Hello,
I am creating a spoon and I am having issues using boolean with the mirrored halves. If anyone can offer advice on how to resolve this I would be grateful.
https://cad.onshape.com/documents/3c5260d2f56409a89a90674f/w/32b71b2238e9574beb7515dc/e/36d500f558e8ba1fc93d7be4
As a side note, is it necessary to make this one part to be used to produce a mold?
I made this spoon example in the past. Maybe this can help you.
https://cad.onshape.com/documents/692dac263cedab385cc51b80/w/830a687a09af19cb1f588c6a/e/2fcdcc32d765cbc6b9145183
In your example, the second loft profile needs to match tangency for the end condition. I would suggest making a smaller surface for just the spoon portion and build the stem out with a second surface. Doing this in one feature will be difficult.
Thanks for the input, John. I attempted your method based on the spoon you sent. I am having issues lofting the handle like yours. I am getting a message that I need to put the profiles in order. I have reordered them but have the same result. Any ideas what could be causing this?
https://cad.onshape.com/documents/73ce6ef76b77c6b745caf804
If you redo the loft feature it seems to be fine. I created a new feature and it seemed to work.
I took a closer look at how the actual spoon was created. The guides used for the fill surface made the surface buckle towards the back.
I tried a different approach by using a line of symmetry and constructions surfaces. This removes the issue at the back of the spoon.
I made a few other changes to the model to help transition the bowl to the handle. It's not perfect, but with some adjustments it can become a lot smoother. Hope this help!
https://cad.onshape.com/documents/a1e61fd6011b6281da30bbfc/w/afe36b162a0616e668d0ae5d/e/fcc795d4901c28bd0a5f8e83
Thank you for the adjustments and guidance. Your solutions were very useful and I am always happy to learn another technique. Splitting the bowl to create a smoother transition was very nice.
https://learn.onshape.com/learn/learning-path/advanced-part-and-surfacing-design
