How do I put a part on the top plan?
vijit_coder
Member Posts: 11 ✭
I need to position the parts for export to STL-file and then print. In this case, the orientation of the model in slicer is important.
As for now, I have to correct the orientation of the model after each export. I want to define its orientation in Onshape for export once.
Tried to do this through Assembly, export from there ignores the position of the part.
I need something like "put the part on the table using that face". I know there are no tables in Onshape
Any ideas?
Thanks, I'll this. This solution is not ideal but it's better then nothing.
So if the part was modeled off of the top plane, then that is where Onshape will import and export it.
I'm looking for a special tool to orient the parts before export.
As suggested @tim_hess427, Transform tool helps with that. No ideal, but good enough.
I made a solution based on suggestion of @tim_hess427. And it's good enough. I created a dedicated PartStudio, derived there all parts and oriented them as they should be printed. A now every change in the working PartStudio reflects there. All I need now is to export the parts and print them. No additional orientation in the slicer. Sweet!
