How to find a part?
LKRENZLERLKRENZLER Member Posts: 30 ✭✭
Let's say I'm working on a document created by someone else and I need to find one of the referenced assemblies or parts.  For example the Spindle in the screenshot.  I would expect to be able to right click and find a path to that part but so far I can't.  I know you can use the search but it's very slow and cranky.  Is there a way to just get the path to where that part is?
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    If you right-click you should see the 'Open Linked' Document option. This will open the referenced assembly in it's respective document. If you get kicked to your main Onshape page and/OR see a blue message then you don't have the right permissions to open the document and must request the right share access.
    Twitter: @bradleysauln
  • LKRENZLERLKRENZLER Member Posts: 30 ✭✭
    edited November 2020
    OK, thanks.  That opens it but in many cases I'm also looking for other parts that I know will be in the same folder.  I still can't see where that document is.  Is there any way to show a path to where it is?  This is what I want to know:
