Is There a Way To Copy a Work Space To a New Doc and Preserve Version History?
larry_hawes
Member Posts: 478 PRO
in General
I get messed up with too many versions sometimes and a new copy of the current doc allows a fresh start, kind of a 'save as' but reveals only the 'main' version. The other versions must be there in some form but I'd like to access them in the new doc copy. Is there a way to do so? Also realize this is pretty weak sauce and a bad method for doc management and perhaps should just manage versions better?
THANKS
THANKS
NeilCooke
Moderator, Onshape Employees Posts: 5,927
You don’t even need to do that. If you select a version (or microversion) so it is active on screen, the menu becomes Copy Version.Senior Director, Technical Services, EMEA6
