Face Shield Model
eric_schimelpfenig
Member Posts: 80 EDU
Hey all! I realized I never posted this here:
https://cad.onshape.com/documents/3eb48dd2e897742bfd684ccd/v/e104c3a0953f7996ac8c7787/e/f88ff88aa0fe388898bb902b
I designed and created a reusable, serviceable face shield a few months ago. It can be cut on a CNC using HDPE and some thin polycarbonate sheet. The whole design is meant to be serviceable so one can break it down, clean it, replace parts and keep them in service.
If anyone wants to make some of these go for it. I've been donating them to people that I know that need them.
2
That's a good tip for sure. In this particular model the tool enters and exits at pretty good angles so there's not too much of a slowdown when you're in the corners. I had pretty good luck cutting runs of these pretty aggressively. The hardest thing is hold down!
I think a 1/4" bit is the best compromise of detail and speed. Although I've seen people use 1/8" bits at full depth through this stuff with good success...
