How do I duplicate a shape by a predefined distance within a sketch?
james_domer
Member Posts: 5 ✭
I am trying to duplicate the only enclosed shape within sketch skPaws within Part Studio 1 of my Untitled Document a predefined distance. The distance in question may be either the length defined by my predefined variable #lenHeelToToe or some distance defined by the separation of any two points already defined in the sketch.
Apologies for not including an image. I was trying to figure that out and failed.
The harder method is to copy a set of sketch entities. First select the entities, right-click, select copy entities. Choose a spot on the screen then right-click and pick paste entities. Use constraints to line it up the way you want and then add a dimension to locate it. This might work better if the entities are not in a horizontal or vertical configuration.
I do know how to create a linear pattern but when the set of patterned elements contains a spline, the pattern function fails. My next thought is to put control points for the spline in the patterned elements, perform the pattern function, and then add the splines last.
