Auto select
Hi. I want to chamfer one edge but auto select selects all edges. How do i turn the auto select off.
EvanReese Member, Mentor Posts: 2,462 ✭✭✭✭✭
I think it actually is, but because the edge you have selected is an arc you're getting a big conical surface that is cutting into the rest of your shape in undesired ways. If you need something different I suggest making a custom path and using a sweep instead.0
Still does not do the one edge selected
Thanks again
