Merging several surfaces into a part gives different error
Hi
I am trying to merge 4 surfaces together using Boolean Union function.
The problem is that I can successfully merge three out of 4 items, but not the fourth one.
The Boolean function indeed highlights the lines with red which are supposed to be problematic. But I really can't understand what is the problem.
Here is the link to the doc https://cad.onshape.com/documents/d6ef1898cbe78bfe502377d6/w/5c9396ba4ab74ae4bae0801d/e/d6b06a2dfd90111f809ce86f
  • oleg_goriunovoleg_goriunov Member Posts: 9
    This is how it looks
  • EvanReeseEvanReese Member, Mentor Posts: 2,452 ✭✭✭✭✭
    What are you wanting to happen with that surface called "Surface restrictor"? it's completely inside the other parts, so even if this worked I'd expect it to just disappear
  • PrachiPrachi Member, OS Professional Posts: 262 ✭✭✭
    A little confused at what your trying to accomplish! Perhaps a description of what end result is intended. There seems to be a lot of extra steps involved in keeping and closing surfaces. The Boolean you are working with includes surfaces that used 'add' when created.
    Hi Evan, Glen,
    Thank you for having a look at the doc!
    The whole thing is a ventilation pipe with a box attached to it. The restrictor is supposed to re-direct part of the airflow (coming from bottom-up) into the box.
    I am creating this model to import it into a physical processes simulator (called simscale). Simscale requires all the components to be one single part.
    The restrictor that is inside the main part is created by extrusion from a line limited by the side surfaces of the box and then split by the horizontal pipe.
    (Alternative variant that I used to make was to create this restrictor by extruding a line limited by the part (three united surfaces: box+horzontal pie + vertical pipe).
    Keeping in mind that I created the restrictor by extrusion limited by the shape of the surrounded objects, I expect it to coincide in size with the volume of the surrounding objects (box + pipes).
    My final aim to to make the whole thing being a single part. (preferable keeping it all surfaces, not transforming (thickening) into a solid. But if surfaces approach won't work, I'd have to go solid).
    P.S. For some very strange reason I am unable to post a new comment for a few hours already (like it is under review)
  • lanalana Onshape Employees Posts: 730
    @oleg_shilovitsky
    You might find it easier to build everything except for "Surface restrictor" as a solid and either hollow it or offset surface with 0 offset, if you want the final model to be a surface.
    In your model the Boolean operation should succeed if Surface restrictor is not selected in it.  It can not be merged with Horizontal Pipe.
    edited December 2020
    Got a little closer with less and I think simpler features. Still will not let me boolean the restrictor into a single surface.
    https://cad.onshape.com/documents/07964c1f8f82cd21f49f477d/w/7d164a9d1caeb961fb2ec834/e/b536af277e55d8944818443e
    That's the point - it lets me unite 3 out of 4 surfaces (except the restrictor) into a single part. but that's not enough.
    I can't figure out how to make all the 4 surfaces a single part.
    Any ideas?
    edited December 2020 Answer ✓
    It has been a while since I looked at Simscale but was pretty sure surfaces were not a requirement. Went back to Simscale and found that a solid model could be imported directly from OS. In the sample here, part 1 in studio 5 imported directly. Have not run the simulation but model details are in place.
    Surface restrictor can not be merged with Horizontal Pipe because such merge would create non-manifold geometry.
    Glen,
    Thanks! Your approach (turning it into solid) worked! Thank you also for the model!
