Hole callout precision
T_Rathier
Member Posts: 47 EDU
When using the hole callout tool there is no option for controlling the precision of the hole diameter or the depth, it just takes on the overall drawing precision. Is there a way to do this?
PeteYodis
Moderator, Onshape Employees Posts: 578
@T_Rathier There is not a way to control precision and tolerance of hole callout parameters yet. If you notice, there is a hole table in part studios where these would also need to show - so this is not a drawings only need. I create a ticket for your request and tie you to that improvement.0 -
PeteYodis
@jonaskuehling I created a ticket for you and tied you to the improvement.0
