Cutting threads
GHamsz
Member Posts: 32 ✭
I’m trying to cut a square thread and have come up against a strange issue. If I position the thread profile so it’s coincident with the helix such that the profile is outside the part I’m cutting the thread in, the Boolean subtraction will fail. If I move the profile into the part I’m threading a slight amount, it works.
The orientation in this picture works, but if I move the profile so that the helix contacts the profile on the upper right point of the square it fails.
Optionsmatthew_stacy Member Posts: 476 PRO@GHammsz, I believe that positioning the swept profile (Sketch 3) coincident with the end-face of the part results in a zero-thickness condition at the start of the sweep (which is computationally problematic for reasons that are way beyond my pay grade).You correctly surmised that moving the profile into the Part alleviates the problem. My preferred approach is to do exactly the opposite, moving the thread profile entirely outside the part. I did this by creating the helix on a construction surface that is longer than the part. There are probably more elegant solutions, but I found this to be serviceable:
5
thank
