Auto select
Hi. I want to chamfer one edge but auto select selects all edges. How do i turn the auto select off.
    I think it actually is, but because the edge you have selected is an arc you're getting a big conical surface that is cutting into the rest of your shape in undesired ways. If you need something different I suggest making a custom path and using a sweep instead.
    uncheck "tangent propagation"
  • gerhard_jansengerhard_jansen Member Posts: 7
    Still does not do the one edge selected
  • mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
    Fillet can't stop suddenly. If you want a sharp stopping point you can try a swept cut instead.
    Thanks. I used the sweep and works as I intended
    Thanks again
