bracket sheet metal
joseph_conlinjoseph_conlin Member Posts: 10 PRO
edited December 2020 in Community Support
I have a a step file of a bracket that was sent me and I need to make the flat version. I imported the part and tried to make a sheet metal part but it is not working please help
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,948 image
    Try creating a sheet metal feature and using the thicken option to select all the faces from one side of the imported part.
  • joseph_conlinjoseph_conlin Member Posts: 10 PRO
    wow! Thank you that worked..
