Dome shape
jamie_brecherjamie_brecher Member Posts: 2 EDU
edited December 2020 in Using Onshape
Hello...I need to make a dome extruded from this face so the cap is rounded....thanks!
  • StephenGStephenG Member Posts: 383 ✭✭✭
    1. Split the top and conical surfaces.
    2. Add an appropriate sketch/profile face.
    3. Create loft using the 2 faces and the profile/face sketch.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,869
    It might even work just using a revolve. Once the face is split in half, revolve one of the faces around the split line.
    Might work in some situations,  but if the intent is to have better control over how the dome transitions into the sides, a loft feature is a better method.
  • EvanReeseEvanReese Member, Mentor Posts: 2,432 ✭✭✭✭✭
    Fill surface could be a good candidate too. Here's a link. The curvature looks ok too, but if I wanted it better, I'd need my profile shape to also be curvature continuous, not arcs and lines.
  • jamie_brecherjamie_brecher Member Posts: 2 EDU
    Thanks to all!
