translating a sketch on a cylinder
Hello all and anyone of assistance,
I am working on my final project for an Onshape-affiliated class. I am in the process of attempting to replicate a french press coffee press. I am trying to translate the attachment sites of the handle onto what is the exterior outside of the notched spaces on the body of the french press. I've managed to use the "wrap" function to affix the elliptical attachment points to the body, however, because I had to approximate where they would go based on having to restrict placement relative to the plane I was sketching in, I would like to translate these sketches onto what would be the hard plastic that is continuous around the body. I tried using the "move plane" function but have a feeling that because it is not a plane that this function is not applicable. Any advice on how I might be able to do this would be most appreciated. I can even share some of the points I get on the assignment with you, if you'd like to share in me getting an A...
Here is the project I am working on. I am assuming that this is the best way to view this project since I can't share it with anyone specifically. https://cad.onshape.com/documents/753600cff23c53fa8a8d257f/w/09d3a04a053fdbdff3833f04/e/eea457fd45832133225b67b5
Thanks in advance.
Alexi
Thanks in advance.
Alexi
I can not open it.
https://cad.onshape.com/documents/5d6a0ec80650003f6f8c8231/w/31d1e273eb8f85932e194ce1/e/ba0d300ea322408ad91a93ed
If not, please ask again.
