can a feature read a version number?
EvanReese
Member, Mentor Posts: 2,852 PRO
I'm kicking around an idea for a feature that labels parts with metadata, which I'd use to keep track of prototype iterations. One of the main bits of info that would be nice to automatically fill is the version number. Is there a way I can read it with FS and convert it to a string? I'm guessing no, for stability reasons, but does anybody have a trick? Another one that I doubt is possible for the same reason would be the date. Any ideas?
Yes, I realize I can set up a variable, and configure the text to make it change lots of places, but setting it up is more work than telling myself I'll use a sharpie, then not labeling the 3D print at all. I am interested in making it frictionless enough to use and more importantly, get a whole team to use.
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,255
This is impossible by design: keep in mind that we want geometry in a version to be fixed. The version name can change. So if FS could read the version name, it would mean that you could change what's in the version just by renaming it, which would be undesirable. (This is also why regenerating FS can't read metadata). I don't think you could automate this with FS.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc-1
Even if you had something that could look at the previous version and assume the current version is the next value from a list (eg. the last version in history is 5, so the current version must be a draft of version 6), I don't know if that would still work when you start branching, merging, and restoring versions. Seems like you run into some time travel paradoxes or something.
I think it would have to work like revisions and revisions tables, where the table shows the the next revision in your scheme with an asterisk and "in progress" watermark. But, that seems like it all operates at a higher level somewhere.
I know this doesn't probably doesn't add much value to the conversation, but I do think it would be awesome functionality to work in at some point. If drawings can do it with Revision data, it shouldn't be impossible with the part studios... ¯\_(ツ)_/¯
I thought that was the case. Thanks for confirming.
In a future world, where 2D paper drawings are less relevant, and manufacturing uses MBD, digital twins, and automated part serialization at the time of manufacturing, wouldn't it make sense to allow for something in the 3D model to be treated the same way as the revision level is treated on a drawing?
A couple thoughts on how this could be done:
1) Just like a timestamp in a git commit, this information is added after the fact but is still a critical part of the file descriptor. Some sort of scaffold could be integrated to allow this.
2) The feature could be generated as part of an export, much like a pre-compiler reading the git hash and substituting it for a text string in the source code, before compiling.
In general, I can see how this is a bit of a delicate issue because the manufacture of the part could actually lead to different part performance. No one wants to track a failed part back to a crack propagating from the letter `I` which has sharper edges than the previous `O`. Still, this is a rare occurrence, and one the designer is responsible for. Much more common is to find a part which fits and to know you want to reproduce that exact part, but struggle to find the original version number.
