Help to repair part - boolen and chamfer
karsten_hjort_gregersen
Member Posts: 11 ✭
Hi
I have made a simple part, which can be found in the enclosed link. Part made on sketch, surface, extrude and thicken. Now I cannot merge all the underlying parts to one part and use chamfer. Can anyone support this and explain how to solve this? Another question is it possible to merge two lines, two faces?
https://cad.onshape.com/documents/b863d139f95a6d598eb8ffd5/w/853d89c7559cd7ad682f52a9/e/5f2260af6d2ce99ae83a8996
Optionskarsten_hjort_gregersen Member Posts: 11 ✭Hi both
Thanks for your support - all good now, appreciated.0
You can use the boolean feature to unite parts together if merging parts does not work.
Onshape Document
https://cad.onshape.com/documents/69d7b4b2ecf4fcb7e418f7cf/w/d971bb81a88fac417041ced9/e/4bbfdbbd7fc4a6fc6b2b228a
The chamfer used on this feature was larger than the thickness of the part. You will need to insert a smaller value.
Let us know how you make out!
