Transform Derived Part and Mate Connectors
Member Posts: 390 ✭✭✭
When I insert a derived part in a part studio, I have to use Transform to correctly place it, but it seems the mate connectors doesn't follow the translation?
  • Moderator, Onshape Employees Posts: 5,839
    Add them to the transform.
    You should be using assemblies for this.
  • Member Posts: 390 ✭✭✭
    ok, got it. Applying Transform to them, as well;). Thanks
    , but I thought you said I should be using one Part Studio for each row of cabinets, instead of one part studio per cabinet in each row?
    I never said that? If a cabinet is a “unit” of your design then it should exist in a part studio on its own.
    Sorry, got confused;). Took it from here:
