How to Sort Array of Strings?
Oliver_LeungOliver_Leung Member Posts: 2 EDU
I have an array of strings that I would like to lexicographically sort using the sort (entities is array, compareFunction is functionfunction, but I'm not sure how to make the comparator function. As far as I can tell, there isn't a built-in string comparator, and I would very much like to avoid hard-coding an ASCII table :smile:
    The easiest way is to make a map, put all the strings as keys in the map, and then iterate over the map -- the strings will come out in order (though this only works if the strings are unique).
  • Oliver_LeungOliver_Leung Member Posts: 2 EDU
    Got it, thanks Ilya! I'm now realizing that there's a "Community Support" section that I probably should've posted in...
    FeatureScript is exactly the right section for this type of stuff.  Sometimes Onshape employees will respond and sometimes other community members.
