Cross Sectional Area of Car (for drag)
haroon_zabair
Member Posts: 5 EDU
Hi, I hope I am not being too much of a noob but I am following a tutorial for a CAD system to make a vehicle aerodynamics wind tunnel. In order to do so, I must input the cross sectional area (of the front of the car) for only half the car - I am only using one side of the car due to lack of necessity. The image I have provided shows how they did it using On Shape in the tutorial. Please could someone highlight how to do this with proper steps. Thanks!
1
Here's how I would find the cross-sectional area of something for aerodynamics (plus the center of pressure as a bonus for flying stuff
https://cad.onshape.com/documents/2250dac4fbab018f4cc3678f/v/36b9eb1e182daa3b198c6f5f/e/b795927e08cf29a1716fbf2e
Using the measure custom feature absolutely isn't necessary, I just like to use it so that I don't have to manually select the face and measure it each time. You can add it here:
https://cad.onshape.com/documents/77baa8153589a7fc5f289829/w/cffd0f2a7077380d5378a885/e/181cb871f3008e6b885df46a
I've used the Silhouette Outline custom feature for this:
https://cad.onshape.com/documents/447c6fe48283e84c4c382e67/v/ac0bdf1d607b2f9b985a2a1f/e/1aca5fb8241964de0b77dd68
@MBartlett21's Project Body custom feature looks like a more advanced version of this, I've just used the outline feature since it's what I'm used to.
https://cad.onshape.com/documents/201b33ee5450cefbca3b34b8/w/95004b1f32bddc1e032970e5/e/03f0c71d4856a8408c7766a0
Hope this helps!
As for drag and lift coefficients, throwing the model into CFD software like SimScale usually lets you get the output forces based on a given wind speed, upward force = lift, backward force = drag, etc. I actually ran this airplane model through a SimScale CFD simulation to try to figure these things out, but I have lots to learn on that front! Here's a video of what it looked like (note the wing stalling out from the turbulent flow behind it):
For making a wind tunnel, I think it isn't really an unreasonable thing to do at home! Not a dumb idea at all! It looks like there are even some kits out there:
https://www.wardsci.com/store/product/8867453/basic-wind-tunnel
Sure, it won't be as scientific as a proper wind tunnel, but it could absolutely be a fun at-home project.
@tony_459 , If you were wondering if Sim Scale has improved, it sounds like they have. I will also leave a link to their vehicle aerodynamics wind tunnel tutorial if you want to check it out - Its great to see a free system have such easy yet in depth features and tutorials to follow.
https://www.simscale.com/docs/tutorials/aerodynamic-simulation-vehicle/
http://cesaretopia.com/cierzscience-tunnel/
https://hackaday.io/project/12080-cierzscience-tunnel
https://youtu.be/g2Y6GBYWttk
