Can I create sketch conics with Featurescript?
EvanReese
Member, Mentor Posts: 2,856 PRO
I expected it to be as easy as skConic but I'm not seeing the option in the documentation. Is it hidden somewhere or not possible for some reason?
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
@Evan_Reese, I found this in the std source. Might be what you already found, but just in case...* Creates a conic section with the given rho value through the start and end points using the control point. * If x is the distance between controlPoint and the line between start and end, and y is the maximum distance between * the conic section and the same line, then rho is x/y. * @param sketch : @autocomplete `sketch1` * @param conicId : @autocomplete `"conic1"` * @param value {{ * @field start {Vector} : * @eg `vector(0, 0) * inch` * @field controlPoint {Vector} : * @eg `vector(0.5, 0.5) * inch` * @field end {Vector} : * @eg `vector(1, 0) * inch` * @field rho {number} : 0 < rho < 0.5 => elliptical arc, rho = 0.5 => parabola, 0.5 < rho < 1 => hyperbola * @eg `0.5` * @field lowParameter {number} : starting parameter of the segment @optional * @field highParameter {number} : ending parameter of the segment @optional * @field construction {boolean} : `true` for a construction conic @optional * @field fixedRho {boolean} : `true` to fix rho during sketch solve @optional * }} */ export function skConicSegment(sketch is Sketch, conicId is string, value is map) precondition { value.start is undefined || is2dPoint(value.start); value.end is undefined || is2dPoint(value.end); value.controlPoint is undefined || is2dPoint(value.controlPoint); value.rho is undefined || value.rho is number; value.lowParameter is undefined || value.lowParameter is number; value.highParameter is undefined || value.highParameter is number; value.construction is undefined || value.construction is boolean; value.fixedRho is undefined || value.fixedRho is boolean; } { return @skConicSegment(sketch, conicId, value); }
2
* Creates a conic section with the given rho value through the start and end points using the control point. * If x is the distance between controlPoint and the line between start and end, and y is the maximum distance between * the conic section and the same line, then rho is x/y. * @param sketch : @autocomplete `sketch1` * @param conicId : @autocomplete `"conic1"` * @param value {{ * @field start {Vector} : * @eg `vector(0, 0) * inch` * @field controlPoint {Vector} : * @eg `vector(0.5, 0.5) * inch` * @field end {Vector} : * @eg `vector(1, 0) * inch` * @field rho {number} : 0 < rho < 0.5 => elliptical arc, rho = 0.5 => parabola, 0.5 < rho < 1 => hyperbola * @eg `0.5` * @field lowParameter {number} : starting parameter of the segment @optional * @field highParameter {number} : ending parameter of the segment @optional * @field construction {boolean} : `true` for a construction conic @optional * @field fixedRho {boolean} : `true` to fix rho during sketch solve @optional * }} */ export function skConicSegment(sketch is Sketch, conicId is string, value is map) precondition { value.start is undefined || is2dPoint(value.start); value.end is undefined || is2dPoint(value.end); value.controlPoint is undefined || is2dPoint(value.controlPoint); value.rho is undefined || value.rho is number; value.lowParameter is undefined || value.lowParameter is number; value.highParameter is undefined || value.highParameter is number; value.construction is undefined || value.construction is boolean; value.fixedRho is undefined || value.fixedRho is boolean; } { return @skConicSegment(sketch, conicId, value); }I had not looked there so thanks for double-checking. I'm still not the best at knowing where to check for this stuff I guess. That got it working for me as expected
