How can I make a composite part of all of the bodies I create in a feature?
I'm writing a feature script to create a ruler or a scale that includes tick marks and numbers. I want to combine all of the ticks and numbers into a single composite part at the end of the feature script.
I first tried
 opCreateCompositePart(context, id, {
            "bodies" : qAllModifiableSolidBodies(),
            "closed" : false
but that put all of the bodies in the part studio into the composite and I only want the parts created in this feature to be in the composite.
I tried creating an array of all of the bodies as I create them.
            tickbodies[i] = qCreatedBy(currentID + "tick", EntityType.BODY);
and then used
                    "bodies" : tickbodies,
                    "closed" : true
That fails because "bodies" is not expecting an array.
What is the elegant way of putting all of these ticks and numbers into a composite part?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,970 image
    Just use qCreatedBy(id) for all bodies created in the current feature.
    edited January 2021
    presumably you creating tick bodies in a loop? if so then before loop you need to define an empty array:
    var tickBodies=[];
    //then if the loop you create new body with operation id depending on some "i" and you append the query of that body to the array.
    for (var i=0, i<N, i+=1; )
    //here you apply some operations creating new body with body creation operation id: id+("tickBody"~i)
    //here you appending array with operation id
    tickBodies = append(tickBodies, qCreatedBy(id+("tickBody"~i), EntityType.BODY));
    //and finally outside of the loop you turn array of queries into the query for multiple bodies wich you can pass to opCreateCompositePart()
    tickBodies = qUnion(tickBodies);
  • monroe_weber_shirkmonroe_weber_shirk Member Posts: 103 EDU
    Elegant! Thank you!
