Using another Sketch as a guide?
ts_2
Member Posts: 22 ✭
I think I would have an easier time if I could make a new sketch, and have it be able to snap to other sketches (points, lines etc.) Think of it as using another sketch as a construction line. Or is this possible somehow? I can't figure it out. The only things I can really snap to are the sketch itself, the origin and maybe the axis lines. Most of the time I think its just origin becomes an active thing to snap a sketch to.
nav
Member Posts: 258 ✭✭✭✭
Hi @ts_2 in order to use a previous sketch as reference you have to use the USE/PROYECT tool on the sketch toolbar and select the entitiess on your sketch you want to use as reference. Here is some info in the help online: https://cad.onshape.com/help/index.htm#cshid=sketch_tools_use
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions5
