How can I use @opWrap to place a label on a cylinder?
monroe_weber_shirk
Member Posts: 96 EDU
I've created a Scale feature that can put a scale (think of one axis of a graph with ticks and numbers) on a plane. I'd like to extend that capability to cylinders so that I can label pipes and round tanks. I've tried to use opWrap and have been unable to figure out what inputs are required. I get the error
@opWrap: Map does not contain field 'anchorPoint'.
I tried adding anchorPoint as a field, but I still get the same error.
The code with opWrap is on line 143
I'd also appreciate any hints on how to debug this type of problem.
Optionslana Onshape Employees Posts: 699https://cad.onshape.com/documents/b3b746e3dc0499469cd57527/w/b9475a19db31b36fa9be5e20/e/354e980fd6fdbc1f8d5e5792
for `source` and `destination` fields of opWrap you need to use WrapSurface types, there are helper functions makeWrapSurface, makeWrapPlane etc. that can be used. Also mate connector (definition.location) can't be used as a face in evPlane, transition from mate connector to plane is plane(evMateConnector(..)).1
