Is There an Offset/Delete Function?
larry_hawes
Member Posts: 478 PRO
in General
I am in the habit (right or wrong) of needing to adjust 3Dn printed parts incrementally until the part is correct for it usage. The method I've been using is an offset. sometimes rather small to sneak up on perfect fit but the offset feature leaves the original sketch line intact and bit on the way. Is there anther method that will both offset and delete the original sketch line?
Probably doesn't need a video but here's the question below.
http://www.youtube.com/watch?v=8S-6igdCLsQ
http://www.youtube.com/watch?v=8S-6igdCLsQ0
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
I would leave the sketch with it nominal geometry and use move face feature on the part faces
If you are extrude or revolve sketch then offset in plane is the same as face offset because face normal is parallel to the sketch plane. But if you extruded with draft (e.g.), face normal is at the draft angle to the sketch plane and face offset will be measured along face normal.
