using "Item label template" to number array items
EvanReese
Member, Mentor Posts: 2,695 PRO
I'm trying to name each item in an array parameter. My first thought was to add a hidden Count Parameter and update it with editing logic, which works, but doesn't update with you just click the button to add a new item. It waits till I change something else. Is there another way to do this? I might be overcomplicating it.
kevin_o_toole_1
Onshape Employees, Developers, HDM Posts: 565
Can you link the code? Unless I'm misunderstanding, adding a new array item should rerun the editing logic function and allow the hidden parameters to be set.0
