Help needed: opMove doesn't behave as I expect
Hi all,
I am experiencing an issue with the `opMoveFace`. The issue is relatively simple. I create a sketch (e.g. a circle) on a plane (let's say the `top` plane). Then, in a feature script, I apply the following operation on the created face (hereafter named `myFace`):
The code gives the expected result only if the `vector(x,y,z)` doesn't lie on the plane of the sketch. Otherwise (i.e. if the vector is outside the plane), no movement at all is applied. Is this a normal behaviour? Can anyone explains to me what's going on?
opMoveFace(context, id + "moveFace1", { "moveFaces" : definition.face, "transform" : transform(vector(definition.x, definition.y, definition.z))});
Thanks,
Francesco
Francesco
Independent Onshape Consultant | Industrial Designer
@evan, yes this is about moving a face in XYZ and after that I need to rotate as well. @neil, it's indeed the case that I can't do this operation with the UI.
I went along a different path so I won't be able to test the proposed operations (opTransform or opPattern) as an alternative. Still I think that from a user perspective it's quite misleading to have an operation (in this case opMoveFace) that works in a way that is misleading.
