Help needed: opMove doesn't behave as I expect
Hi all,
I am experiencing an issue with the `opMoveFace`. The issue is relatively simple. I create a sketch (e.g. a circle) on a plane (let's say the `top` plane). Then, in a feature script, I apply the following operation on the created face (hereafter named `myFace`):
opMoveFace(context, id + "moveFace1", {
"moveFaces" : definition.face,
"transform" : transform(vector(definition.x, definition.y, definition.z))});
The code gives the expected result only if the `vector(x,y,z)` doesn't lie on the plane of the sketch. Otherwise (i.e. if the vector is outside the plane), no movement at all is applied. Is this a normal behaviour? Can anyone explains to me what's going on?
Thanks,
Francesco
  • EvanReeseEvanReese Member, Mentor Posts: 2,879 PRO
    The goal is to just move a given face anywhere in space by XYZ coordinates? I haven't tested and am not certain, but opPattern might be a better tool for it. You should be able to feed it the same inputs. Assuming the feature would only move one face, you could just throw any string into an array for instanceNames like ["myInstanceName"].
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,997 image
    The way to test it is to see if you can perform those operations manually with the UI. I’m not sure that will work. opTransform or opPattern would be better.
  • francesco_norifrancesco_nori Member Posts: 4
    Thanks for the replies!
    @evan, yes this is about moving a face in XYZ and after that I need to rotate as well. @neil, it's indeed the case that I can't do this operation with the UI.
    I went along a different path so I won't be able to test the proposed operations (opTransform or opPattern) as an alternative. Still I think that from a user perspective it's quite misleading to have an operation (in this case opMoveFace) that works in a way that is misleading.
