DWG: Dimension to center of slot cutout?
JollyJolly Member Posts: 81 PRO
Having a hard time figuring out how to give a dimension to the center of a pin slot. The cutout is slotted as part of an alignment feature and the slot is there so the mating, pinned component doesn't bind. But on the drawing I can't dimension to the center of the slot, just the two circular edges. Any advice? I already went and re-did the sketch/cut with a new slot sketch to ensure it was "seen" as a slot sketched feature vs a couple arcs and lines. But that didn't work.
  • JollyJolly Member Posts: 81 PRO
    Including a simplified screenshot for clarity. The slot is below and I can dimension to the ends of it (5.25 & 4.86) but not the center (theoretically 5.06).
  • romeograhamromeograham Member, csevp Posts: 712 PRO
    You can show the sketch that created the slot (Sketches from the Part studio can be shown in drawing views...but you can't create sketches in drawings yet). Right-click the drawing view and select "show sketches" ... scroll through the list and select the one you want. Once you click the green check, the sketch will appear on the drawing view, and you can dimension to it.
    If you don't have a sketch in the Part Studio that includes ONLY the slot reference, then you can create one, label it "slot dimension sketch" or something...then show THAT sketch in your drawing. Just make sure it's constrained properly to your slot so it remains parametric as needed.
    Hope that helps,
    Romeo
    Yeah, I didn't think of making just a slot-sketch specific for the drawing. I had pulled in the sketch but it was full of other things I didn't want.  that should work. Thanks!
