modifier keys and manipulator change functions
EvanReeseEvanReese Member, Mentor Posts: 2,856 PRO
is there a way to use modifier keys with a manipulator change function? For example if I have a set of point manipulators I can only pick one at a time, is there a way to pick multiple while holding SHIFT?
    It's not currently possible for a points manipulator to specify multiple points simultaneously. Please submit an improvement request if this is functionality you want!
  • EvanReeseEvanReese Member, Mentor Posts: 2,856 PRO
    Thanks, Kevin. I'd love this functionality for the Freeform Spline. The awesome Meta Sculpt feature has a workaround for multiple selections, which I'll have to dig into and see if it can work for me. I would love to be able to make the selection of point manipulators more similar to the selection of other things in Onshape:
    1. persistant selection
    2. click whitespace or spacebar to deselect
    Freeform spline is really still just a stand-in until something like 3D sketches rolls around. Sketch constraints with a 3D spline would be a game changer. I would use coincident/pierce a ton for this if I easily could.
