modifier keys and manipulator change functions
EvanReese
Member, Mentor Posts: 2,686 PRO
is there a way to use modifier keys with a manipulator change function? For example if I have a set of point manipulators I can only pick one at a time, is there a way to pick multiple while holding SHIFT?
kevin_o_toole_1
Onshape Employees, Developers, HDM Posts: 565
It's not currently possible for a points manipulator to specify multiple points simultaneously. Please submit an improvement request if this is functionality you want!0
- persistant selection
- click whitespace or spacebar to deselect
Freeform spline is really still just a stand-in until something like 3D sketches rolls around. Sketch constraints with a 3D spline would be a game changer. I would use coincident/pierce a ton for this if I easily could.The Onsherpa | Reach peak Onshape productivity
