Exporting as an STL
caroline_read
Member Posts: 31 ✭
Hi,
I am making a part to try and send it to my Makerbot Replicator 2x but when I export my files from OS as an STL, Makerbot Desktop isn't able to open the files. Does anyone know if this is an OS thing or me doing something wrong?
Anyone else have similar experiences?
The printer does work with a SolidWorks file exported as an STL.
--> The file I'm trying to use from OS does work if I download it as a Solidworks file then change the file type to STL from Solidworks. I'd like it if I didn't have to go through Solidworks.
I just shared the file over to you. Thank you!
When I export my document how can I download it to my computer or to makerbot desktop?
https://www.onshape.com/videos/training-working-with-imported-data
STL out is at the 23:27 mark
Check the bottom of your Chromebook screen- a tab should appear which you can click to locate your download
OR check your "Download" folder under "Files"...
In all probability you've already checked these - I mention them because I don't know how much familiarity you have with Chrome OS.
Thanks!
