Some mate don't follow when insert an assembly in another assembly
alain_kinloughalain_kinlough Member Posts: 3
Hello all,
My problem is that i create many parts in a folder, create an assembly that seem to be fully constraint, when i move it it move in one block.
I create some other part in another folder, create another assembly fully constraint.
I insert my first assembly in the second assembly successfully for the insert but some mate of the insert assembly seem to be lost (ie: my first assembly was split in 3 parts!!)
I need to rebuild the lost mate!
Why?
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,437
    Did you use fix? Fix is not mate - it is only for keeping parts still in the current assembly only.  Group if you want to keep the parts together.
    Thanks,
    I'm new with OnShape, came from SolidWorks, and after many try, found i have forgot 2 mates between my parts. Now every thing works like one parts.
