Working with Imported Models in Onshape: Strategy for import and part studio tricks?
martin_kopplow202
Member Posts: 10 ✭
Check out Tips and Tricks for Working with Imported Models in Onshape on Onshape Learning Center: https://learn.onshape.com/learn/video/tips-and-tricks-for-working-with-imported-models-in-onshape
Dear Onshape Team,
during the past hours or so I have listened to and worked though some
of the material related to working with imported geometry. Most of this
material discusses the tools, but not the strategy. I still have not
figured out how to actually access imported models for editing beyond
the direct editing tools and also keep them in the assembly structure
(or adequately reintroduce them). It appears I missed some important
point, since there seems no way to access the parts like them being not
transferable into part studios or do not import within the places in the
structure they were meant to be. Obviously, in my sample case, all non-solid parts went
into an assembly now named "Non-Solid parts" which neither was in the
parasolids source data, not did I create it.
Could someone point me to a tutorial or training material that
addresses the aspect of 'strategical importing for editing', please?
Best,
Martin
Onshape mainly uses solid parts:
SLDPRT or Parasolid
You can use other file types, but you may not be able to easily edit them like solid parts.
Importing solid parts
RENDERCAD
RENDERCAD
yes, I chose the 'split into multiple documents' option since I wanted to keep the assembly structure. There are some parts in it I cannot share here, though.
The 'return to main' option is there, and if I followed that path and made a new version, which is okay, but still leaves me without the parts being transferrable into any part studios. The option to create a part studio solo or in context is there, but they come into life as empty, and once I go to a part studio, I can't find any way to transfer a part there for editing. It's kind of strange, since this must be a common thing to do, right? Can't I just create a part studio for a selected part, drag and drop the part into it, send or copy it there, or so?
So what I did was:
- Import a parasolid assembly via a zip file.
- opened the root assembly
- all (nearly) my parts are there, most as sub assemblies, some as parts, in original order, except non-solids, which are now found in a "Non-Solid Parts" section that is not even a proper subassembly*.
- created a part studio (tried in context and solo).
- tried to move geometry there. The only way to do so appears to offset every face by zero, so a copy appears in the part studio? Does not work for curves, though, and looks like a dirty workaround to me.
Is there a tutorial that describes the process of importing assemblies for editing in part studios? I haven't found any. All I found was how to do it with a single part, and that is not an option for me, for I have too many nested subassemblies.
I will try again, but this Issue needs to be resolved, for I have other projects coming, which include a few hundred subassemblies or parts, and require a more or less automated process when importing from Catia.
Best,
Martin
*Strange, kind of! Though the non-solid elements were originally unfinished elements of parts that had their place in the tree.
