Sheet metal flanges - Error & Non-Error with same feature sequence
IsoworksIsoworks Member Posts: 22 PRO
Hello,
I was hoping I could find some clarification to the issue that I am having. I have tried every workaround I could come up with.
Here is a link to the model.
 https://cad.onshape.com/documents/da3a70869b47f3999450acf7/w/7171c9ada02d83d0f0213349/e/0106c97127bcc24bdc584805
The issue is that I would like to create flanges on the inside of a rectangular opening. The flanges are perpendicular to each other.
In the successful implementation I was able to create a relief cut which allowed the creation of perpendicular flange without pattern overlap. See picture below.
In the unsuccessful implementation of this relief cut I cannot get OnShape to recognize the cut. It will sketch the cut but it will not implement. The closest I can get is to the picture below.
I have even tried creating a 89 degree relief at the end of the flange to allow for the apparent interference.
What is different?
Any assistance would be greatly appreciated.
Regards,
Ian Osborne
    @Isoworks, I wasn't able to open the document.  Please confirm the url.
  • IsoworksIsoworks Member Posts: 22 PRO
    @matthew_stacy, my bad. I didn't have this set as public. And I haven't been in the forums for a while. I have changed the model completely so the the exact issue is no longer relevant. However, the issue of cuts being recognized in SheetMetal is still very relevant. I find this very frustrating.
