"Spinning Clock" in lower right corner of a Parts Studio?
christopher_owens
Member Posts: 235 ✭✭
I had a "Spinning Clock" in the lower right hand corner of a Parts Studio that would not "go away", even through I could continue to work in the work space. There was a previous operation that Onshape had some issue with that kept displaying an "error" message at the top of the window, telling me to contact support and had a long "code" number. Do you click on that number??? That finally went away. I got rid of the clock by going out of the document, into another (no clock), and back into the first document. After loading the studio data and graphics the clock went away after a couple seconds. I can only assume Onshape righted itself! I was about to go into the history to try to "go back in time"!
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
The spinner in the bottom right corner indicates that there is something that is in process, usually a feature that is being computed.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
shashank_aarya
Member Posts: 265 ✭✭✭
In heavy documents having higher number of features and parts, regeneration time between features goes on increasing and same process is indicated by spinning clock5
Spinning clock at the lower right corner shows loading symbol…I’m also faced problems like this, when my internet speed is too slow.
