Batch-deleting missing external references from a sketch?
in General
It happens often that after I edit something on which some external references for a later sketch exist, the sketch goes red.
I know this doesn't really affect the features next in line and all I have to do is to delete those missing constraints, but sometimes a sketch uses many external references and I have to delete them one by one because those don't seem to be multi-selectable.
I think it would be great to be able to delete those all at once.
5
Yes, it is a useful approach.!
Have you put an improvement request in for this yet? It would be a MASSIVE help to be able to only remove missing references in sketches the way you can with the SW display/delete references!!
https://forum.onshape.com/discussion/19283/select-and-delete-multiple-sketch-constraints#latest
