Is it possible to create an aligned section view?
jford
Member Posts: 2 PRO
I'm trying to create an aligned section view on an adapter plate that has 5 holes equally spaced and a center keyway. Since there are 5 holes they are note symmetrical. I would like to create an aligned section that cuts through one hole, the keyway and another hole. Is this possible with Onshape?
