shell tool not working even with no fillets.
I was trying to make a shell for a rc car and I wanted to make a shell with the opening on the bottom and it highlights every edge red, at first it was highlighting all fillets red so I removed them and it still will not work.
link https://cad.onshape.com/documents/441e0349dce7bcbfaa910491/w/c376e711c56ff7b6e30c7635/e/2d58665f6e5542c90dbc19ac
I was able to shell after deleting your Sketch 8 but the Shell only works for about .05" thick. Your details are causing failure at thickness greater than that.
you will likely need to use a different strategy. First make the main shape that will be wall thickness, then add the small details.
