Im trying to determine which constraint to use
michael_marriam
Member Posts: 8 ✭
I have three parts. The first part fits through the second and the two rotate w.r.t. each other. The third part fits in a slot on the second and slides w.r.t it.
Ive established a rotating constraint between part one and two which functions as desired. I can get the third part to slide in the second with a sliding constraint but I can't get it to rotate with the second around part one.
Is this what you are after? Fix the blue block, Cylindrical mate dark grey to blue, Slider mate light grey to dark.
Sharing it will get you a ton of help from the generous folks in this forum community.
