Disable Automatic Inferencing?
timothy_jump
Member Posts: 22 ✭
Is there a way to disable the Automatic Inferencing? It is a more effective when teaching students geometry if they must add critical references manually.
timandrews
Member, Moderator, Onshape Employees Posts: 18
@timothy_jump, there is currently no way to permanently disable inferencing when sketching. However, you can disable inferencing temporarily by holding the "Shift" key.
5
shift does not turn off an active inference (orange showing). you need to move the cursor out of any inference. Then hold shift which keeps inferences from happening.
