Joint Smoothing Problem?
Hello,
I'm trying to joint 3 pieces together. I put a .5" fillet on the edges of my pieces, and am trying to somehow smoothen the triangular shape of the blue piece that appears. Does anyone have an idea of how to do this?
As you can see, I don't want to put a fillet on the bottom or side edges of the dark blue piece or it will take away from the smooth transition between  it and the other pieces. I just want to remove the triangle that is formed.
Thank you to anyone who takes the time to read this, I really appreciate it!
  • steve_shubinsteve_shubin Member Posts: 1,116 ✭✭✭✭
    @yuval_mader
    Revolve set to Remove
    @yuval_mader
    After looking a bit more at the pictures you posted, it seems that not everything is at 90° angles to one another. And this will make a difference in how you make the round or fillet at the inside corner
    Because of the above, I employed the USE TOOL And then did a LOFT with GUIDE
    Take a look at the 3 GIFs below
