How to update Feature Studio contents using python client?
Hi!
I can successfully access feature studio content using python client API by:
But any tries to call update_feature_studio_contents end up with:
So far I've tried:
1. Use API explorer to create working json like: '{"contents": "AAAAAAAAAAAAAAAAA", "serializationVersion": "1.1.20", "sourceMicroversion": "483f72f012aa6e1a6c6853ba", "rejectMicroversionSkew": false}' It works in browser/API explorer.
2. Use it as a body in the call to update_feature_studio_contents -> does not work.
Here is my code:
Best regards,
Oleksandr
element = OnshapeElement("https://cad.onshape.com/documents/ca8f441b906a5949eb4e8196/w/3ffa603f8af8def1150f37d7/e/f85267336902055c5cbf495d")This gives me valid result with something like:
result = osh.client.feature_studios_api.get_feature_studio_contents(
**element._get_DWMVE(),
_preload_content=True
{'btType': 'BTFeatureStudioContents-2239', 'contents': 'FeatureScript 1447;\n' 'import(path : "onshape/std/geometry.fs", version : "1447.0");\n' '\n', 'library_version': 0, 'microversion_skew': False, 'reject_microversion_skew': False, 'serialization_version': '1.1.20', 'source_microversion': '422f02088f68947019b7c291'}
Traceback (most recent call last): File "/usr/lib/python3/dist-packages/IPython/core/interactiveshell.py", line 3331, in run_code exec(code_obj, self.user_global_ns, self.user_ns) File "<ipython-input-46-d4661d04e8f2>", line 1, in <module> result = osh.client.feature_studios_api.update_feature_studio_contents( File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api/feature_studios_api.py", line 613, in __call__ return self.callable(self, *args, **kwargs) File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api/feature_studios_api.py", line 410, in __update_feature_studio_contents return self.call_with_http_info(**kwargs) File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api/feature_studios_api.py", line 670, in call_with_http_info return self.api_client.call_api( File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api_client.py", line 367, in call_api return self.__call_api( File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api_client.py", line 184, in __call_api response_data = self.request( File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api_client.py", line 447, in request return self.rest_client.POST( File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/rest.py", line 400, in POST return self.request( File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/rest.py", line 312, in request raise ApiException(http_resp=r) onshape_client.oas.exceptions.ApiException: (400) Reason: Bad Request HTTP response headers: HTTPHeaderDict({'Date': 'Mon, 08 Feb 2021 21:28:36 GMT', 'Content-Type': 'application/json;charset=utf-8', 'Content-Length': '91', 'Connection': 'keep-alive', 'On-Version': '1.125.26734.a33400e3c8f4', 'On-Request-Id': '742b3dce8e437fe70dc6de1c', 'Strict-Transport-Security': 'max-age=31536000; includeSubDomains', 'X-Content-Type-Options': 'nosniff', 'X-XSS-Protection': '1; mode=block'}) HTTP response body: { "moreInfoUrl" : "", "message" : "Error in input", "code" : 9999, "status" : 400 }Is there any working example of how to change the content of the feature studio using API?
So far I've tried:
Here is my code:
element = OnshapeElement("https://cad.onshape.com/documents/ca8f441b906a5949eb4e8196/w/3ffa603f8af8def1150f37d7/e/f85267336902055c5cbf495d")Many thanks for any suggestion!
resp = json.dumps({
"sourceMicroversion": result["source_microversion"],
"rejectMicroversionSkew": False
body=resp
Best regards,
Oleksandr
The Python client does not fully support the update feature studio content endpoint yet. You can get around this be formulating the call directly. I've made an example here: https://github.com/onshape-public/onshape-clients/blob/next/python/test/test_feature_studios_api.py#L5
This could save a bunch of time for people who care about automation.
