Self Assessment Answers
jason_nicholas_jths
Member Posts: 3 EDU
Hi.
My students are going through the learning CAD Basics learning pathway. I have a couple of questions.
1. As a teacher, can I see their progress and completed self-check assessments?
2. Is there an answer key for the self-check assessments so that they know what questions they got right/wrong?
Attached is short video clip of assessment.
Any information is helpful as Onshape is a new and wonderful world to me.
Thank you kindly.
https://screencast-o-matic.com/watch/cYQbIvJC1c
Thank you kindly.
1. There isn't currently a way to track progress in the learning center from another account as far as I know. The workaround is to have students send screenshots once they complete a section.
2. When you submit an answer for the self-check, it will tell you whether you got it right or not. If you get it wrong, it will tell you what the right answer was and will give you a link to a solution document so that you can learn from it and try again. That looks like this:
I hope this helps!
1. Thanks for the work around tip.
2. I am not seeing the answer responses. Maybe it has to do with the type of assessment.
Here is a short video clip.
@alnis_smidchens is correct- currently there is not a way to track the students progress.
However we did provide public documents of all models in a completed state- so you should be able to decipher the correct answer from there. There are a handful of quizzes throughout the Learning Center that are not modeling questions, that currently we do not provide an answer key- I will add it to our to do list!
