Self Assessment Answers
jason_nicholas_jths
Member Posts: 6 EDU
Hi.
My students are going through the learning CAD Basics learning pathway. I have a couple of questions.
1. As a teacher, can I see their progress and completed self-check assessments?
2. Is there an answer key for the self-check assessments so that they know what questions they got right/wrong?
Attached is short video clip of assessment.
Any information is helpful as Onshape is a new and wonderful world to me.
Thank you kindly.
https://screencast-o-matic.com/watch/cYQbIvJC1c
Thank you kindly.
Hi @jason_nicholas_jths! Welcome to the forums. I'm not an Onshape employee, but I believe the answers to your questions are:
1. There isn't currently a way to track progress in the learning center from another account as far as I know. The workaround is to have students send screenshots once they complete a section.
2. When you submit an answer for the self-check, it will tell you whether you got it right or not. If you get it wrong, it will tell you what the right answer was and will give you a link to a solution document so that you can learn from it and try again. That looks like this:
I hope this helps!Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.0 -
@alnis_smidchens. Hi. Thank you for your response.
1. Thanks for the work around tip.
2. I am not seeing the answer responses. Maybe it has to do with the type of assessment.
Here is a short video clip.
@alnis_smidchens is correct- currently there is not a way to track the students progress.
However we did provide public documents of all models in a completed state- so you should be able to decipher the correct answer from there. There are a handful of quizzes throughout the Learning Center that are not modeling questions, that currently we do not provide an answer key- I will add it to our to do list!
Unless I'm missing something in the responses to @jason_nicholas_jths question, I have a similar question having (finally) started the self-training. I think the point of the question was for the Q & A portion of the training and not the CAD exercises. When you complete the self assessment questions it only tells you the percentage of correct answers. The summary does not tell you which questions you go right or wrong irrespective of the correct answer. I can understand if the training wants you to go through the section material again rather than divulge the answer, but at least indicate which questions were wrong.Regards,0
This is a real problem from an instructor AND student perspective. On the spacial reasoning exercises, if they AT LEAST told you which one you got wrong, then it would help. I am forced to ignore these exercises, since I can't keep going through them trying to guess which one I got wrong. I could help my students with tips to solve, but this is just way too time consuming. Teachers need an answer sheet in order to effectively communicate the best methods for problem solving. Not to mention the fact that as teachers, we many times are using faulty lessons. At least we can figure those out and make the lesson work.I just create my own lessons, and ignore those self-checks. When we are done with COVID, I'll be back to using Inventor.0
You should be able to figure out the right answer from the public documentation we provided of all the models in their final form. I will make sure to include it on our to-do list! At the moment, we do not offer an answer key for a small number of exams in the Learning Center that do not pertain to modeling. @ Geometry Game
