Dimensions change with import
IsleofGoughIsleofGough Member Posts: 26
I created a 10 foot cube in Rhino 7 and the dimensions in Rhino are correct at 10 feet per side. When I import this in Onshape, the dimensions increase to a little over 11 feet and I have the  preferences set to the same "foot" units. Is there a way to avoid the rescaling in Onshpae?
  • IsleofGoughIsleofGough Member Posts: 26
    It looks like it is a bug in Rhino import. If I export from Rhino as STEP, it works ok in Onshape. However, importing and exporting back to Rhino does indeed change the scale.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    Please use the "report a bug" option in the Onshape help menu and share the Rhino file with support.
    Done. It is a bug.
    Thank you, Onshape team, for fixing this in most recent update.
    You're welcome :)
